Multiple Instances not Starting
OS Name/Version: Ubuntu 23.10
Product Name/Version: 2.5.0.0
Problem Description: Updated AMP and now Enshrouded and Space Engineers Instances will not start. Tried Fetch Latest and Updating Instances to latest but still does not start
Enshrouded - Preparing to Start Application
*blank*
Space Engineers
16:38:36
tid(79) burning pthread_key_t == 0 so we never use it
minidumps folder is set to /tmp/dumps
16:38:37
UpdateUI: skip show logoSteam Console Client (c) Valve Corporation - version 1709846822
-- type 'quit' to exit --
Loading Steam API...OK
force_install_dir "298740"
16:38:38
Waiting for user info...OK
"@sSteamCmdForcePlatformType" = "windows"
app_update 298740 -beta public validate
16:38:39
16:38:41
Update state (0x5) verifying install, progress: 15.12 (968737757 / 6409111766)
16:38:43
Update state (0x5) verifying install, progress: 34.53 (2212791649 / 6409111766)
16:38:45
Update state (0x5) verifying install, progress: 52.46 (3362032690 / 6409111766)
16:38:47
Update state (0x5) verifying install, progress: 70.41 (4512634350 / 6409111766)
16:38:49
Update state (0x5) verifying install, progress: 88.06 (5643580826 / 6409111766)
16:38:51
Update state (0x61) downloading, progress: 0.00 (0 / 22784864)
16:38:53
Update state (0x61) downloading, progress: 41.42 (9437184 / 22784864)
16:38:55
Update state (0x61) downloading, progress: 90.80 (20687712 / 22784864)
dlmopen steamservice.so failed: steamservice.so: cannot open shared object file: No such file or directory
Success! App '298740' fully installed.
quit
16:38:56
Console16:39:23
wine: Unhandled exception 0xe0434352 in thread 5dc at address 00006FFFFF463DF7 (thread 05dc), starting debugger...
  • Start either a Space Engineers Instance or Enshrouded
  1. Created new instance of SpaceEngineers to Test
  2. Same issue. SpaceEngineers refuses to start.
  3. Created new instance of Enshrouded to Test
  4. Issue May be fixed. I just moved all the data to a new instance as a workaround
Show us the contents of the support tab please.
I have the same issue I believe.
“Copy support data to clipboard” does not appear to be doing anything so I grabbed these details thinking it might be what you’re looking for. Docker AMP bug - Pastebin.com
Same problem with Space Engineers instance…
┃ Key                  ┃ Value                                 ┃
┃ Operating System     ┃ Linux - Debian GNU/Linux 12 on x86_64 ┃
┃ Product              ┃ AMP 'Callisto' v2.5.0.0 (Mainline)    ┃
┃ Virtualization       ┃ Docker                                ┃
┃ Application          ┃ Space Engineers                       ┃
┃ Module               ┃ GenericModule                         ┃
┃ Running in Container ┃ Yes                                   ┃
┃ Current State        ┃ Stopped                               ┃
10:41:19
Console
10:47:21
wine: Unhandled exception 0xe0434352 in thread 1b0 at address 00006FFFFF463DF7 (thread 01b0), starting debugger…
10:47:26
wine: Unhandled exception 0xe0434352 in thread 818 at address 00006FFFFF463DF7 (thread 0818), starting debugger…
10:47:32
wine: Unhandled exception 0xe0434352 in thread 62c at address 00006FFFFF463DF7 (thread 062c), starting debugger…
10:47:37
wine: Unhandled exception 0xe0434352 in thread 2e0 at address 00006FFFFF463DF7 (thread 02e0), starting debugger…
10:47:43
wine: Unhandled exception 0xe0434352 in thread 634 at address 00006FFFFF463DF7 (thread 0634), starting debugger…
SteamCMD
10:53:33
tid(17143) burning pthread_key_t == 0 so we never use it
10:53:34
– type ‘quit’ to exit –
Loading Steam API…OK
force_install_dir “298740”
10:53:36
10:53:37
Waiting for client config…OK
Waiting for user info…OK
@sSteamCmdForcePlatformType” = “windows”
10:53:39
Update state (0x5) verifying install, progress: 4.72 (302460087 / 6409111766)
10:53:41
Update state (0x5) verifying install, progress: 11.23 (719963107 / 6409111766)
10:53:43
Update state (0x5) verifying install, progress: 17.64 (1130750489 / 6409111766)
10:53:45
Update state (0x5) verifying install, progress: 23.89 (1531377300 / 6409111766)
10:53:47
Update state (0x5) verifying install, progress: 30.38 (1947030428 / 6409111766)
10:53:49
Update state (0x5) verifying install, progress: 36.92 (2366015588 / 6409111766)
10:53:51
Update state (0x5) verifying install, progress: 43.32 (2776153905 / 6409111766)
10:53:53
Update state (0x5) verifying install, progress: 49.90 (3198156334 / 6409111766)
10:53:55
Update state (0x5) verifying install, progress: 56.36 (3612006160 / 6409111766)
10:53:57
Update state (0x5) verifying install, progress: 62.92 (4032449613 / 6409111766)
10:53:59
Update state (0x5) verifying install, progress: 69.33 (4443501002 / 6409111766)
10:54:01
Update state (0x5) verifying install, progress: 76.06 (4874686954 / 6409111766)
10:54:03
Update state (0x5) verifying install, progress: 82.71 (5300935549 / 6409111766)
10:54:05
Update state (0x5) verifying install, progress: 89.41 (5730424702 / 6409111766)
10:54:07
Update state (0x5) verifying install, progress: 95.88 (6144999791 / 6409111766)
10:54:09
10:54:10
Success! App ‘298740’ fully installed.
quit
10:54:11
Console
10:54:38
wine: Unhandled exception 0xe0434352 in thread 10c at address 00006FFFFF463DF7 (thread 010c), starting debugger…
10:54:43
wine: Unhandled exception 0xe0434352 in thread 180 at address 00006FFFFF463DF7 (thread 0180), starting debugger…
10:54:49
wine: Unhandled exception 0xe0434352 in thread 208 at address 00006FFFFF463DF7 (thread 0208), starting debugger…
10:54:54
wine: Unhandled exception 0xe0434352 in thread 290 at address 00006FFFFF463DF7 (thread 0290), starting debugger…
10:55:00
wine: Unhandled exception 0xe0434352 in thread 318 at address 00006FFFFF463DF7 (thread 0318), starting debugger…
┃ Key                  ┃ Value                                 ┃
┃ Current State        ┃ Failed                                ┃
having same issue on fresh install of SE
