Hello,
is it possible to install AMP on a Linux Server where is „KeyHelp“ installed too? Keyhelp is a free alternative to Plesk/cPanel.
Hello,
I don’t see any reason why not. If you’re using a Webserver other than nginx just make sure to select no to HTTPS during setup.
yeah there shouldn’t be any problems but do note that if the KeyHelp panel uses port 8080, then there might be a problem but amp will try and use 8081
Okey i will try. Thank you.
