OS Name/Version:
Debian Linux Bookworm
AMP 2.5 - 20240314.2
Rust with uMod / Oxide without Container
First i upgraded the Rust01 instance and it stayed on 2.4.8. I had to upgrade through console.
After it was 2.5.0 it starts but in AMP it stays in status "STARTING" and no log is available.
It worked like a charme for a long time. Now it doesn't work anymore.
And also it doesn't install umod / oxide. I tried to install it manually (copy files) and it's still not starting.
I don't know what's going on.
"Application State: Starting"
I updated the server with steam, tried to reinstall umod. No chance.
Updated all AMP instances, all AMP tools and upgraded whole OS.
Also done:
ampinstmgr upgradeall
Tried to install a completly new server, same problem:
All other servers are running. It’s only Rust. Also if i install a new Rust server → Same behaviour.
[Info] Port usage for Rust01 (Rust)
[Info] Instance is currently running.
[Info] LISTENING 8082 TCP (Core.Webserver.Port)
[Info] LISTENING 2225 TCP (FileManagerPlugin.SFTP.SFTPPortNumber)
[Info] LISTENING 28015 UDP (RustModule.Rust.Port)
[Info] LISTENING 28016 UDP (RustModule.Rust.QueryPort)
[Info] LISTENING 5678 TCP (RustModule.Rust.RconPort)
[Info] LISTENING 28082 TCP (RustModule.Rust.AppPlusPort)
Update: uMod/Oxide is working if i install it manually and deactivate the “install umod” option. Server is working like always but AMP doesn’t get over the
And no chance to see the log in AMP.
